kein LAN Verbindung
23-10-2016, 19:39
mad kein LAN Verbindung
The LAN communication of my 101KR/LAN panel is not working although I can communicate to the panel with PING command.
When I try to connect remotely via internet I get the message “No supported device has been found(control panel not responding). Also testing the LAN via DNS TEST remain RED LIGHT.
The System has been activated for MY JABLOTRON APP. When I unplug the LAN Cable, I do see a message in the HISTORY of the MY JABLOTRON APP: there is a time stamp with “FAULT LAN communicator. Besides that I receive an SMS message from +420606999015: MyJABLOTRON-HEINS (22:18): FAULT(LAN-communicator). When I plug in again, I get message on My Jablotron app, that LAN fault has been repaired
Also a section alarm is reported in MyJABLOTRON and same SMS message from +420606999015.
I also get a sms-messge from the panel straight forward with name “unknown_80”, where normally the message starts with JABLOTRON 100 HEINS, which is system name.
For some reason my panel is unknown in the cloud. Communication from the panel to Jablotron cloud is working but not from Cloud to Panel! Does anybody have an idea how to solve.
Thank you for help me further!
  Kommunikation App und Zentrale / JA101 K LAN Basti988 4 3.479 01-10-2023 09:21
  JA-101K Lan - Batterie Aussensirene wechseln SandyValandy 8 7.422 30-08-2023 20:01
  GSM oder LAN Verbindung? valbuz 2 3.937 10-12-2020 14:41
Letzter Beitrag: valbuz
  LAN-Modul nachrüsten PE-tag 16 17.146 26-11-2019 07:30
Letzter Beitrag: PE-tag
question Lan Kommikationsstoerung dermitdemwolftanzt 1 3.754 17-03-2017 13:53
Letzter Beitrag: Suroma
  Hife wegen Zugriff auf JA 100 via APP /LAN Andreas27 5 7.276 17-07-2016 14:29
  No LAN communication heins1959 0 3.612 19-03-2016 12:20
Letzter Beitrag: heins1959
  Problem LAN Jablotron 100 Freki1971 15 18.600 28-01-2016 00:46
Letzter Beitrag: Freki1971
  Datenverbindung LAN bzw. GSM?? Zapper 6 9.240 29-07-2015 10:49
Letzter Beitrag: schalldruck
  LAN Schnittstelle Fragen Rufus 8 11.595 22-05-2015 14:56
