No LAN communication
19-03-2016, 11:20
The LAN communication of my 101KR/LAN panel is not working although I can communicate to the panel with PING command.
When I try to connect remotely via internet I get the message “No supported device has been found(control panel not responding). Also testing the LAN via DNS TEST remain RED LIGHT.
The System has been activated for MY JABLOTRON APP. When I unplug the LAN Cable, I do see a message in the HISTORY of the MY JABLOTRON APP: there is a time stamp with “FAULT LAN communicator. Besides that I receive an SMS message from +420606999015: MyJABLOTRON-HEINS (22:18): FAULT(LAN-communicator). When I plug in again, I get message on My Jablotron app, that LAN fault has been repaired
Also a section alarm is reported in MyJABLOTRON and same SMS message from +420606999015.
I also get a sms-messge from the panel straight forward with name “unknown_80”, where normally the message starts with JABLOTRON 100 HEINS, which is system name.
For some reason my panel is unknown in the cloud. Communication from the panel to Jablotron cloud is working but not from Cloud to Panel! Does anybody have an idea how to solve.
Thank you for help me further!
Best regards,
Jelle
  Kommunikation App und Zentrale / JA101 K LAN Basti988 4 2.562 01-10-2023 08:21
Letzter Beitrag: Jens Knoche
  JA-101K Lan - Batterie Aussensirene wechseln SandyValandy 8 4.748 30-08-2023 19:01
  GSM oder LAN Verbindung? valbuz 2 3.209 10-12-2020 13:41
Letzter Beitrag: valbuz
  LAN-Modul nachrüsten PE-tag 16 13.360 26-11-2019 06:30
Letzter Beitrag: PE-tag
question Lan Kommikationsstoerung dermitdemwolftanzt 1 3.187 17-03-2017 12:53
Letzter Beitrag: Suroma
mad kein LAN Verbindung Olaf6 0 2.855 23-10-2016 18:39
Letzter Beitrag: Olaf6
  Hife wegen Zugriff auf JA 100 via APP /LAN Andreas27 5 6.124 17-07-2016 13:29
  Problem LAN Jablotron 100 Freki1971 15 15.924 27-01-2016 23:46
Letzter Beitrag: Freki1971
  Datenverbindung LAN bzw. GSM?? Zapper 6 7.902 29-07-2015 09:49
Letzter Beitrag: schalldruck
  LAN Schnittstelle Fragen Rufus 8 9.873 22-05-2015 13:56
