Secvest Glasbruchmelder an Funköffnugsmelder anschliessen
07-06-2010, 13:39
Mein Deutsch ist nicht so gut also ich schreibe auf Englisch. Ich kann auch übersetzen, wenn jemand interessiert ist aber kein Englisch kann.
I wanted to buy some passive "Glasbruchmelder" and connect them to the "Funköffnungsmelder" but obviously the instruction manual (of the Funköffnugsmelder) assumes that the user already knows the basics... There are a lot of drawings at the end of the manual and in the main text, there is a drawing that includes two resistors. My impression is that the resistors have to be added only if you want to connect your own device but not another Abus detector. Is that correct? But then what is the configuration if you simply want to connect a Glassbruchmelder? I also read it is theoretically possible to connect more detectors in a serial way. In case of "Doppelfügeligefenster", would it be possible to connect to the main "Funköffnungsmelder" a wired "Öffnungsmelder"(for the other window) and two "Glasbruchmelder" (one for each window)? What would be the configuration then? Since that seems pretty complicated I was wondering if a single seismic sensor wouldn't be more appropriate but it is as reliable? Many thanks for your help! Vielen Dank! |
08-06-2010, 14:22
RE: Secvest Glasbruchmelder an Funköffnugsmelder anschliessen
[/i]
(07-06-2010 13:39)nichtbeimir schrieb: Mein Deutsch ist nicht so gut also ich schreibe auf Englisch. Ich kann auch übersetzen, wenn jemand interessiert ist aber kein Englisch kann. You're welcome please come back with more information[i] Wissen vermehrt sich durch Teilung |
09-06-2010, 14:45
Thank you so much for your reply.
Here is the link to the product: http://www.abus-sc.de/silver.econtent/ca...er/FU8320W You can click on the Installationsanleitung to download it. The drawings of all possible configurations are on page 50 and following. The Glasbruchmelder is here: http://www.abus-sc.de/silver.econtent/ca...er/FU7300W and the wired "Öffnungsmelder": http://www.abus-sc.de/silver.econtent/ca...ss/MK1010W If I understand it correctly, there are two zones in the Funköffnungsmelder so the alarmzentrale is able to distinguish between the signal coming from the opening detector and that of the 'Glasbruchmelder" (if only one Glasbruchmelder is connected of course and not the wired opening detector and glass breakage detector connected together serially to zone 2). The problem is one of my windows is a "Doppelflügelige Fenster mit Unterlicht" and if I want to monitor everything separately it's a lot of hardware... A single "Erschütterungsmelder" on that window would be simpler. On the other hand I don't want to take the risk of a lot of false alarms and my experience with the faulty "Bewegungsmelder" makes me suspicious about the reliability of these devices... Many thx again for your help![/u] |
