  • 65 Bewertungen - 2.91 im Durchschnitt
Secvest Glasbruchmelder an Funköffnugsmelder anschliessen
07-06-2010, 13:39
Mein Deutsch ist nicht so gut also ich schreibe auf Englisch. Ich kann auch übersetzen, wenn jemand interessiert ist aber kein Englisch kann.
I wanted to buy some passive "Glasbruchmelder" and connect them to the "Funköffnungsmelder" but obviously the instruction manual (of the Funköffnugsmelder) assumes that the user already knows the basics... There are a lot of drawings at the end of the manual and in the main text, there is a drawing that includes two resistors. My impression is that the resistors have to be added only if you want to connect your own device but not another Abus detector. Is that correct? But then what is the configuration if you simply want to connect a Glassbruchmelder?
I also read it is theoretically possible to connect more detectors in a serial way. In case of "Doppelfügeligefenster", would it be possible to connect to the main "Funköffnungsmelder" a wired "Öffnungsmelder"(for the other window) and two "Glasbruchmelder" (one for each window)? What would be the configuration then?
Since that seems pretty complicated I was wondering if a single seismic sensor wouldn't be more appropriate but it is as reliable?
Many thanks for your help! Vielen Dank!
08-06-2010, 14:22
RE: Secvest Glasbruchmelder an Funköffnugsmelder anschliessen
[/i]
(07-06-2010 13:39)nichtbeimir schrieb:  Mein Deutsch ist nicht so gut also ich schreibe auf Englisch. Ich kann auch übersetzen, wenn jemand interessiert ist aber kein Englisch kann.
Believe me, my German is better than my English. Some say, however, I also can not German. Anyway, I hope you understand me at least Blush
Hi nichtbeimir,
welcome to the alarmforum.
I need more background information
This is of course always helpful
Can you publish these drawings here?
The resistors are usually the sabotage monitoring of the signal line
Depends on the technical design of the component. Resistors are integrated or not switched off etc. ..
once again ... depending on the technical design of the component.
Technically it is possible to switch to alarm contacts of passive components in series. The mixing of glass breakage detector UDN magnetic contact is not recommended for maintenance. They also have a totally different characteristics. So always one line per alarm message type
In general, I think not.
Please note the basic requirement
Windows should be against upheld (magnetic contact) and climb (with glass breakage detector secured).
Both versions get a dedicated reporting line to the burglar alarm.
All components should be only from one producer
You're welcome
please come back with more information
[i]
Wissen vermehrt sich durch Teilung
09-06-2010, 14:45
Thank you so much for your reply.
Here is the link to the product:
http://www.abus-sc.de/silver.econtent/ca...er/FU8320W
You can click on the Installationsanleitung to download it. The drawings
of all possible configurations are on page 50 and following.
The Glasbruchmelder is here:
http://www.abus-sc.de/silver.econtent/ca...er/FU7300W
and the wired "Öffnungsmelder":
http://www.abus-sc.de/silver.econtent/ca...ss/MK1010W
If I understand it correctly, there are two zones in the Funköffnungsmelder so the alarmzentrale is able to distinguish between the signal coming from the opening detector and that of the 'Glasbruchmelder" (if only one Glasbruchmelder is connected of course and not the wired opening detector and glass breakage detector connected together serially to zone 2).
The problem is one of my windows is a "Doppelflügelige Fenster mit Unterlicht" and if I want to monitor everything separately it's a lot of hardware... A single "Erschütterungsmelder" on that window would be simpler. On the other hand I don't want to take the risk of a lot of false alarms and my experience with the faulty "Bewegungsmelder" makes me suspicious about the reliability of these devices...
Many thx again for your help![/u]
  sg1650 an FUAA50000 anschliessen BigBen 9 8.388 24-10-2015 09:41
  Anschliessen von Glasbruchmelder Fu7300 an Funköffnungsmelder FUMK 50000 Dirk254 5 7.938 28-11-2014 19:13
Letzter Beitrag: Manfredo
  ABUS Secvest Öffnungsmelder mit Glasbruchmelder m.m.bos 3 10.675 25-02-2014 17:22
Letzter Beitrag: Flieger340
  Externes Mikrofon an Secvest 2way anschliessen mwhattal 5 6.233 19-01-2014 11:08
  Secvest 2Way: Welchen Typ für den Glasbruchmelder FU7300 einstellen? Gjila1 18 24.793 06-01-2014 09:47
Letzter Beitrag: PTSS
  Abus Secvest 2Way USB Kabel anschliessen soll ne Katastrophe sein? Gjila1 21 21.257 09-08-2013 17:51
Letzter Beitrag: NordseeAlarm
  Magnetkontakt an FU8320 anschliessen Gjila1 7 6.864 01-08-2013 10:39
Letzter Beitrag: Gjila1
  Secvest 2way Funk Öffnungsmelder an Doppelflügelfenster anschliessen. Geht das?? Gjila1 7 10.424 09-07-2013 19:31
  secvest 2 way - Glasbruchmelder sup-fehler theex 0 2.762 08-07-2013 21:29
Letzter Beitrag: theex
