how to see signal strength on devices and enter service mode?
27-10-2017, 16:40
How do i see the devices signal strengh in Olink software?
And how do i enter servicemode on the control panel? i've got the code. |
28-10-2017, 14:52
RE: how to see signal strength on devices and enter service mode?
Hello Molino,
You enter the Servicemode on the BT by the code. *0 <code>. Dependent on the code you select automatically the Service or Mastermode. Have a look on the display of the BT when you enter the code. You will then see the Mode. In Olink you must choose Servicemode. Klick the button "devices". Select a registered Device right click and choose properties. You will then see in the section "RF Signal Level" the signal strength of the device. Dont worry if you see 0%. The strength will be logged only when you in Service mode and the device was triggert. To see the actually signal strength trigger the device and you will see immediately the value. Regards Christian Murphys Law: Man hat niemals Zeit, es richtig zu machen, aber immer Zeit, es noch einmal zu machen. |
03-12-2017, 18:14
hi again,
If i want to test my smoke alarm (i've got a special gas to spray) how do i setup the central so i can test if it works? |
03-12-2017, 19:10
Dear Molino,
I can not really recommend to use such aerosol sprays. After use there will likely remain a thin smudge layer on the optical devices of the smoke detector. This smudge can seriously lead to malfunctions. The smoke detectors for use in homes according DIN 14604 have to be equipped with a self test function (just a button). This function is sufficant for the test procedure. All detectors of the 8000 system can be tested in the service mode. Just activate the remote display by opening it, than open the device to activate it for the test mode. Now test it. Dipl. Ing. Stefan Brandt, Oberhausen, info@heimtek.de, www.heimtek.de |
| Batteriewechsel and Sabotage Alarmproblem | tom1234 | 18 | 3.395 |
12-10-2026 20:52 Letzter Beitrag: sicherheitstechnik-siegen |
| Service bei einer Oasis - Zeitaufwand | sicherheitstechnik-siegen | 8 | 3.785 |
14-11-2025 20:31 Letzter Beitrag: Escorpio |
| Meldung am Bedienteil:Service fällig Zentrale | Kugelblitz | 2 | 4.959 |
03-01-2020 18:27 Letzter Beitrag: Kugelblitz |
| Eingangsverzögerung / Signal und mehrere Fragen | happiness | 9 | 10.487 |
20-02-2019 10:51 Letzter Beitrag: happiness |
| Service fällig Zentrale Meldung | Jurist | 1 | 6.162 |
02-01-2017 21:25 Letzter Beitrag: timbaum |
| Ereignisse Service | Timi | 0 | 2.548 |
23-09-2015 08:25 Letzter Beitrag: Timi |
| AC-88 neben JA80-L - kein Signal | bastelwastel | 1 | 3.398 |
22-02-2015 11:32 Letzter Beitrag: Thomas_6683 |
