DS6750/DS7700 und Fritzbox vs. Switch
21-09-2023, 12:50
RE: DS6750/DS7700 und Fritzbox vs. Switch
Hätte ich mal nichts geschrieben :-(
21.09.23 at 11:54:39: "DS7700 absent"
Leider ist es wieder weg.
Im log habe ich mal ein grep auf den genutzten Port gemacht:
Code:
USW-24-PoE-UM.6.5.59# cat  messages | grep "Port 17"
Sep 18 15:47:41 USW-24-PoE kern.notice kernel: [784293.020000] Port 17 link up
Sep 18 15:47:41 USW-24-PoE kern.warn kernel: [784293.080000] Port 17 moving from Disabled to Blocking
Sep 18 15:47:43 USW-24-PoE kern.warn kernel: [784295.330000] Port 17 moving from Blocking to Forwarding
Leider keine Einträge von heute.
Und hier die letzten 50 Einträge aus dem Log:
Code:
Sep 20 17:37:32 USW-24-PoE kern.notice kernel: [963672.230000] Port 9 link down
Sep 20 17:37:32 USW-24-PoE kern.warn kernel: [963672.350000] Port 9 moving from Forwarding to Disabled
Sep 20 17:37:33 USW-24-PoE kern.notice kernel: [963673.870000] Port 9 link up
Sep 20 17:37:33 USW-24-PoE kern.warn kernel: [963674.100000] Port 9 moving from Disabled to Blocking
Sep 20 17:37:35 USW-24-PoE kern.warn kernel: [963676.100000] Port 9 moving from Blocking to Forwarding
Sep 20 20:00:12 USW-24-PoE kern.notice kernel: [972231.840000] Port 9 link down
Sep 20 20:00:12 USW-24-PoE kern.warn kernel: [972232.010000] Port 9 moving from Forwarding to Disabled
Sep 20 20:00:15 USW-24-PoE kern.notice kernel: [972235.480000] Port 9 link up
Sep 20 20:00:15 USW-24-PoE kern.warn kernel: [972235.510000] Port 9 moving from Disabled to Blocking
Sep 20 20:00:18 USW-24-PoE kern.warn kernel: [972238.260000] Port 9 moving from Blocking to Forwarding
Sep 20 20:15:08 USW-24-PoE daemon.info : process '/sbin/udhcpc -f -i eth0 -V ubnt -A 10 -s /etc/udhcpc/udhcpc -p /var/run/udhcpc.eth0.pid -h USW-24-PoE' (pid
Sep 20 20:15:08 USW-24-PoE daemon.info : starting pid 7937, tty '/dev/null': '/sbin/udhcpc -f -i eth0 -V ubnt -A 10 -s /etc/udhcpc/udhcpc -p /var/run/udhcpc.eth0.pid
Sep 20 20:15:08 USW-24-PoE user.info : uplink-monitor[383]: uplink-monitor.update(): entering isolated state
Sep 20 20:15:10 USW-24-PoE user.notice syswrapper: ipready.eth0 = 172.16.0.11
Sep 20 20:15:11 USW-24-PoE user.notice syswrapper: ipready.eth0 = 172.16.0.11
Sep 20 20:17:13 USW-24-PoE kern.notice kernel: [973252.880000] Port 9 link down
Sep 20 20:17:13 USW-24-PoE kern.warn kernel: [973253.040000] Port 9 moving from Forwarding to Disabled
Sep 20 20:17:15 USW-24-PoE kern.notice kernel: [973254.530000] Port 9 link up
Sep 20 20:17:15 USW-24-PoE kern.warn kernel: [973254.540000] Port 9 moving from Disabled to Blocking
Sep 20 20:17:17 USW-24-PoE kern.warn kernel: [973257.290000] Port 9 moving from Blocking to Forwarding
Sep 20 21:49:21 USW-24-PoE kern.notice kernel: [978780.990000] Port 9 link down
Sep 20 21:49:22 USW-24-PoE kern.warn kernel: [978781.220000] Port 9 moving from Forwarding to Disabled
Sep 20 21:49:25 USW-24-PoE kern.notice kernel: [978784.740000] Port 9 link up
Sep 20 21:49:25 USW-24-PoE kern.warn kernel: [978784.970000] Port 9 moving from Disabled to Blocking
Sep 20 21:49:28 USW-24-PoE kern.warn kernel: [978787.220000] Port 9 moving from Blocking to Forwarding
Sep 20 22:01:01 USW-24-PoE kern.notice kernel: [979480.900000] Port 19 link down
Sep 20 22:01:01 USW-24-PoE kern.warn kernel: [979480.990000] Port 19 moving from Forwarding to Disabled
Sep 20 22:01:06 USW-24-PoE kern.notice kernel: [979486.120000] Port 19 link up
Sep 20 22:01:07 USW-24-PoE kern.warn kernel: [979486.240000] Port 19 moving from Disabled to Blocking
Sep 20 22:01:09 USW-24-PoE kern.warn kernel: [979488.240000] Port 19 moving from Blocking to Forwarding
Sep 20 22:01:21 USW-24-PoE kern.notice kernel: [979500.880000] Port 19 link down
Sep 20 22:01:21 USW-24-PoE kern.warn kernel: [979500.990000] Port 19 moving from Forwarding to Disabled
Sep 20 22:02:05 USW-24-PoE kern.notice kernel: [979544.440000] Port 19 link up
Sep 20 22:02:05 USW-24-PoE kern.warn kernel: [979544.490000] Port 19 moving from Disabled to Blocking
Sep 20 22:02:08 USW-24-PoE kern.warn kernel: [979547.240000] Port 19 moving from Blocking to Forwarding
Sep 21 08:15:10 USW-24-PoE daemon.info : process '/sbin/udhcpc -f -i eth0 -V ubnt -A 10 -s /etc/udhcpc/udhcpc -p /var/run/udhcpc.eth0.pid -h USW-24-PoE' (pid
Sep 21 08:15:10 USW-24-PoE daemon.info : starting pid 28343, tty '/dev/null': '/sbin/udhcpc -f -i eth0 -V ubnt -A 10 -s /etc/udhcpc/udhcpc -p /var/run/udhcpc.eth0.pid
Sep 21 08:15:11 USW-24-PoE user.notice syswrapper: ipready.eth0 = 172.16.0.11
Sep 21 08:55:06 USW-24-PoE user.info : mca-monitor[389]: mca-monitor.do_monitor(): collector not responding, elapsed=1018791 (max=300)
Sep 21 08:55:06 USW-24-PoE user.notice syswrapper: kill-inform-collector. reason: inform-collector not responding
Sep 21 08:55:06 USW-24-PoE daemon.info : process '/bin/inform-collector' (pid 390) exited. Scheduling for restart.
Sep 21 08:55:07 USW-24-PoE daemon.info : starting pid 31344, tty '/dev/null': '/bin/inform-collector'
Sep 21 08:55:08 USW-24-PoE daemon.info : process '/bin/inform-collector' (pid 31344) exited. Scheduling for restart.
Sep 21 08:55:08 USW-24-PoE daemon.info : starting pid 31347, tty '/dev/null': '/bin/inform-collector'
Mir gehen die Ideen aus :-(
RE: DS6750/DS7700 und Fritzbox vs. Switch - 26196008 - 21-09-2023 12:50
  DS6750 - Texte definieren bei den Ausgängen Roelli 1 1.019 17-11-2024 15:16
Letzter Beitrag: Herki
  DS7700 -Ansagetexte SammyHH 8 4.508 04-06-2023 07:08
Letzter Beitrag: Privateruser
  DS7700 Reparatur? SammyHH 16 5.548 18-05-2023 20:49
  E-Mail DS7700 Nightcrawler 3 2.963 14-04-2023 20:04
  561-MB24 DS6750 Firmware-Update 26196008 12 9.138 05-05-2022 08:44
Letzter Beitrag: 26196008
  DS6750 Stehende Verbindung(IP) + Redundante Stehende Verbindung (GSM) Daniel_1990 7 4.930 04-11-2021 14:55
Letzter Beitrag: Daniel_1990
  Bootloader V2 für DS7700 gesucht Alarmfuzzy0354 1 3.307 23-09-2021 07:33
Toungue Umstellung | Honeywell MB48+DS9500 zu MB48+DS6750 Daniel_1990 4 4.529 19-07-2021 08:45
  DS7700 kein Ethernet mehr StephanK 14 8.471 05-07-2021 22:11
  DS7700 SMS Versand an D2 über 7580 Fritz VOIP Anschluß mptoecker 7 6.762 14-06-2021 21:56
Letzter Beitrag: ManniTom
