Terxon MX 8-Zone Wireless Extension
30-06-2019, 12:31
Hello All
I have an interesting problem.
I have MX setup with two extensions Wired and Wireless.
They work well and no issues with fitting or setting them up.
About 3years ago i added two FU8305 wireless panic buttons.
The setup was very easy and the wireless range was very good, so no issues.
I ran a test on the buttons over 4 months ago, and the Alarm Unit returned an error.
TELECMD LOW BATT, and the keypad showed a RED light.
I cannot CLEAR the error.
Is there any way to CLEAR the error without replacing the panic buttons?
(I have tried and failed to replace the batteries in the panic button) I have removed the panic buttons by de-paring them off the system.
The Alarm unit is OK, I can still ARM and DISARM However I always see the error and the red light on the keypad.
There are NO other issues with the setup, no other error events in the logs.
Any advice?
14-09-2019, 13:23
RE: Terxon MX 8-Zone Wireless Extension
All.. I have reset the TELECMD LOW BATT fault. Here is what i have learnt.
1. The downloader software will NOT reset these types of faults
2. Disconnecting (removing the from setup/memory) the wifi devices i.e FU805 from the wifi extension unit will NOT work.
It seems the wifi extension continues to send the last fault to the control panel. So I disconnected the extension unit from the system, the control panel returned another fault (Extension 2 missing). I had to reconnect the extension and that cleared both faults.
Good news i no longer see the RED fault LED on the keypads.
(I guess one question : i dont recall a configuration setting for the number of extension units so why did the control panel see the missing extension (i only disconnected the power from that unit) I suspect its the wiring method as I was unable to reset that fault. Hence i had to reconnect the extension unit before it cleared)?!? Any thoughts?
14-09-2019, 18:29
Hi
I can't answer your question but thanks for giving that Feedback to us.
Regards
Sektionschef
Instar IN-5907HD
  Terxon LX - Anzeige der auslösenden Zone Wombats 9 4.592 08-12-2023 22:32
Letzter Beitrag: Donald
  Zone für alle Bereiche, A, B, C, D, auf NV stellen Delago17 2 2.903 01-03-2023 10:09
Letzter Beitrag: Delago17
  Zone Sab auf alle gruppen vanturenhout 29 15.178 25-12-2022 13:44
  terxon mx gehtest: zone schlägt nicht an tombalabomba 15 9.429 03-09-2021 19:48
  Terxon S zone 4 offen Ohk1985 14 10.581 17-07-2021 10:00
  Fehlalarme in einer einzigen Zone Terxon M Vogels 27 17.527 26-11-2020 13:50
Letzter Beitrag: Berggeist
  Terxon MX - Benutzer Rechte nur für seine Zone Westice 23 19.268 30-03-2020 09:03
smile Terxon LX per App steuern. Wie schaltet die Zone? Terxonsebas 22 18.617 25-09-2019 13:40
Letzter Beitrag: Terxonsebas
  Terxon S Zone C aktivieren - wie? trybear 8 9.317 06-05-2019 09:16
Letzter Beitrag: Sektionschef
  Terxon MX Fehlalarm Zone Dennyoo 7 8.603 17-03-2019 20:33
