  • 136 Bewertungen - 2.76 im Durchschnitt
Secvest 2way Erfahrungen
11-06-2010, 14:06
RE: Secvest 2way Erfahrungen
>Well maybe I have been too quick in my statement. I have just read about an idle time of 3 minutes in the manual. So apparently once the 'Bewegungsmelder' has >detected something, it does not trigger any alarm any more during this timeframe (the manual says that this idle time is reduced to 10 seconds during the first 30 >minutes after the tamper is released or the batteries are installed). That would partly explain the strange behaviour.
O.k. I am editing this message to share my findings: according to the last version of the manual, available as a download, there is indeed a 3-minute freeze that applies even when you activate the alarm (you can reduce it to 1 minute by removing a jumper though). That's why they say one shoudn't use it as an exit/entry zone.
But after some more testing, I have concluded that the one I have behave normally except that... the sensitivity is way too low! It detects me only when I am less than 3 meters from the detector perhaps. Not farther. I even tried to crawl on the ground like a cat (what would one do to test an alarm!!!) and I am totally undetected. And this is not the "Tierimmun" version that I have! So I will return it.
I contacted the retailer from whom I purchased the device and apparently they are responsible for the customer service, not directly ABUS.
Secvest 2way Erfahrungen - Felle - 10-01-2010, 19:29
RE: Secvest 2way Erfahrungen - Toxx - 11-01-2010, 10:46
RE: Secvest 2way Erfahrungen - Xerox - 04-05-2010, 20:29
RE: Secvest 2way Erfahrungen - Xerox - 08-05-2010, 11:24
RE: Secvest 2way Erfahrungen - Xerox - 09-05-2010, 02:10
RE: Secvest 2way Erfahrungen - Ollik - 11-06-2010, 01:05
RE: Secvest 2way Erfahrungen - nichtbeimir - 11-06-2010 14:06
RE: Secvest 2way Erfahrungen - Mar5us - 23-11-2011, 18:12
RE: Secvest 2way Erfahrungen - Gilo - 01-02-2012, 20:01
  Secvest 686 oder Secvest 2way kofrank 9 10.614 27-04-2015 08:41
Letzter Beitrag: kofrank
  Secvest 868 Komponenten an die Secvest 2Way? Gjila1 14 14.499 22-06-2014 19:18
Letzter Beitrag: Gjila1
  Erfahrungen mit Funk-Fenstergriff FU 8435 W / 350 E SecvestUser 3 5.496 22-12-2013 23:15
Letzter Beitrag: Xerox
  Secvest FU8000+ Bewegungsmelder Erfahrungen holterwok 2 4.667 16-08-2013 19:34
Letzter Beitrag: frky
  FU 8230 Secvest 2Way Funk-Innensirene für Secvest 868 Funkalarmzentrale ??? Danny 9 14.654 01-03-2013 19:40
  Secvest 2Way; Erfahrungen Chris G 0 5.473 16-03-2012 08:54
Letzter Beitrag: Chris G
