Scantronic R7500 cannot detect PIR 714R?
27-07-2014, 09:53
Scantronic R7500 cannot detect PIR 714R? | |||
27-07-2014, 10:27
RE: Scantronic R7500 cannot detect PIR 714R?
Hi Roarslot,
if the former Batterie longer was empty, you may put off the new battery and connect the + and - from your PIR with a wire or another metall. Then try it again. best regards megagramm AK Engineering Sicherheitstechnik Energietechnik Haustechnik Thermografie für Hamburg und Umgebung Errichter für die Systeme von Jablotron, Telenot und ABUS |
28-07-2014, 19:19
Hi megagramm,
Thank you for your answer. I tried to short circuit the plus and minus in the PIR sensors, but no luck. Best Regards Roar Slot |
28-07-2014, 21:23
wenn you put the new battery in, ist the red LED blinking? try to push the sabotage button for a few seconds an several times. best regards megagramm AK Engineering Sicherheitstechnik Energietechnik Haustechnik Thermografie für Hamburg und Umgebung Errichter für die Systeme von Jablotron, Telenot und ABUS |
02-08-2014, 09:06
Yes, led is blinking red. But the R7500 does not detect them, still. I have tried pushing the sabotage button several time for all three sensors, but no luck. Best Regards Roar Slot |
02-08-2014, 12:46
try to delete the PIR on your R7500 completly. Then try again to learn it on your R7500. best regards megagramm AK Engineering Sicherheitstechnik Energietechnik Haustechnik Thermografie für Hamburg und Umgebung Errichter für die Systeme von Jablotron, Telenot und ABUS |
03-08-2014, 06:04
That I did from the beginning. Best Regards Roar Slot |
Scantronic 9851 Fehlalarme, wie Zone sperren | Delago17 | 5 | 1.806 |
01-03-2023 09:13 Letzter Beitrag: Delago17 |
Pir Funktion? | Gunman | 5 | 4.849 |
11-03-2016 23:38 Letzter Beitrag: Gunman |
Sabotagealarm - Scantronic? | sabsl40 | 0 | 3.624 |
20-12-2010 20:35 Letzter Beitrag: sabsl40 |
Scantronic Funkalarmanlage | KuRSuN | 1 | 5.060 |
16-01-2010 17:15 Letzter Beitrag: konti.at |
