  • 5 Bewertungen - 3 im Durchschnitt
Scantronic R7500 cannot detect PIR 714R?
27-07-2014, 09:53
My Scantronic R7500 cannot detect my three Pir 714R sensors?
Jamming is set to off.
The batteries are new.
I activate the sabotage function by opening the lid of the sensor
I have also tried pushing the tamper/sabotage button
What can be the issue.
You can answer in German also :-)
27-07-2014, 10:27
RE: Scantronic R7500 cannot detect PIR 714R?
Hi Roarslot,
if the former Batterie longer was empty, you may put off the new battery and connect the + and - from your PIR with a wire or another metall.
Then try it again.
best regards
megagramm
AK Engineering
28-07-2014, 19:19
Hi megagramm,
Thank you for your answer.
I tried to short circuit the plus and minus in the PIR sensors, but no luck.
Best Regards
Roar Slot
28-07-2014, 21:23
wenn you put the new battery in, ist the red LED blinking?
try to push the sabotage button for a few seconds an several times.
best regards
megagramm
AK Engineering
02-08-2014, 09:06
Yes, led is blinking red. But the R7500 does not detect them, still.
I have tried pushing the sabotage button several time for all three sensors, but no luck.
Best Regards
Roar Slot
02-08-2014, 12:46
try to delete the PIR on your R7500 completly.
Then try again to learn it on your R7500.
best regards
megagramm
AK Engineering
03-08-2014, 06:04
That I did from the beginning.
Best Regards
Roar Slot
  Scantronic 9851 Fehlalarme, wie Zone sperren Delago17 5 3.555 01-03-2023 09:13
Letzter Beitrag: Delago17
  Pir Funktion? Gunman 5 6.046 11-03-2016 23:38
Letzter Beitrag: Gunman
  Sabotagealarm - Scantronic? sabsl40 0 4.090 20-12-2010 20:35
Letzter Beitrag: sabsl40
  Scantronic Funkalarmanlage KuRSuN 1 5.743 16-01-2010 17:15
Letzter Beitrag: konti.at
