  • 5 Bewertungen - 3 im Durchschnitt
Scantronic R7500 cannot detect PIR 714R?
27-07-2014, 10:53
My Scantronic R7500 cannot detect my three Pir 714R sensors?
Jamming is set to off.
The batteries are new.
I activate the sabotage function by opening the lid of the sensor
I have also tried pushing the tamper/sabotage button
What can be the issue.
You can answer in German also :-)
27-07-2014, 11:27
RE: Scantronic R7500 cannot detect PIR 714R?
Hi Roarslot,
if the former Batterie longer was empty, you may put off the new battery and connect the + and - from your PIR with a wire or another metall.
Then try it again.
best regards
megagramm
28-07-2014, 20:19
Hi megagramm,
Thank you for your answer.
I tried to short circuit the plus and minus in the PIR sensors, but no luck.
Best Regards
Roar Slot
28-07-2014, 22:23
wenn you put the new battery in, ist the red LED blinking?
try to push the sabotage button for a few seconds an several times.
best regards
megagramm
02-08-2014, 10:06
Yes, led is blinking red. But the R7500 does not detect them, still.
I have tried pushing the sabotage button several time for all three sensors, but no luck.
Best Regards
Roar Slot
02-08-2014, 13:46
try to delete the PIR on your R7500 completly.
Then try again to learn it on your R7500.
best regards
megagramm
03-08-2014, 07:04
That I did from the beginning.
Best Regards
Roar Slot
  Scantronic - Terxon MX/Reset Sabotage Deckel Delago17 0 851 23-04-2026 13:50
Letzter Beitrag: Delago17
  Scantronic 9851 Fehlalarme, wie Zone sperren Delago17 5 5.113 01-03-2023 10:13
  Pir Funktion? Gunman 5 7.762 12-03-2016 00:38
Letzter Beitrag: Gunman
  Sabotagealarm - Scantronic? sabsl40 0 4.694 20-12-2010 21:35
Letzter Beitrag: sabsl40
  Scantronic Funkalarmanlage KuRSuN 1 6.575 16-01-2010 18:15
Letzter Beitrag: konti.at
