Trouble assigning proximity card to user
30-08-2015, 13:22
I'm using a INT KLCDR keypad including proximity reader. When I try assign a proximity card to a user using DloadX, the card is not read and the card number is not visible in DloadX. However the keypad backlight is lit when the card gets near, so it seems the reader is working fine. Any thoughts?
Fixed by adding the proximity card via the keypad itself. No problem there fortunately. |
01-09-2015, 08:41
RE: Trouble assigning proximity card to user
Fixed, when I tried to assign cards directly from the keypad, instead of DloadX, it worked fine.
User zum Quittieren eines Brandalarms | g0nz00 | 0 | 776 |
23-01-2023 11:37 Letzter Beitrag: g0nz00 |
An alle Mac-User: DLOADX über Mac? Bzw. Alternative zur Notlösung "Parallels"? | Knappe Frank | 2 | 1.770 |
16-07-2022 09:58 Letzter Beitrag: Funkalarmprofi |
