Sirene Alarmcom/Siemens SA6
02-10-2021, 07:32
Good morning,
I am from Italy and new of this forum.
I have got a siren of Alarmcom/Siemens model SA6.
Since I have dismounted my alarm system to do many works in home, now I have reconnected all the components but I have lost the instruction manual of the siren SA6 and I don't remember how to reconnect it to the system. Is there anyone who can help me? Thank you very much in advance for any help.
02-10-2021, 12:03
RE: Sirene Alarmcom/Siemens SA6
http://www.mr-sicherheitstechnik.ch/kund...ge/SA6.pdf
www.km-sicherheitstechnik.de
Alarmanlagen u.A. von Telenot | Videoverifikation | Mobile Alarmanlagen für Baustellen und Leerstand | Schutznebel | IP-Kameras
____________________
Impressum für Beiträge mit gewerblichen Inhalten: https://km-sicherheitstechnik.de/impressum
02-10-2021, 12:29
(02-10-2021 12:03)KMsicherheitstechnik schrieb:  http://www.mr-sicherheitstechnik.ch/kund...ge/SA6.pdf
Thank you so much!
I too found this one, but the pin out is different from the one I have.
I mean ... the pin out on my siren has 8 pins named:
> " X X X " the first three;
> " - Z + " the second three (- should be negative; + positive; Z probably is alarm signal coming from the head unit ...)
> " L L " the last two (L should stand for "Light" as I see they are directly connected to the flashing bulb lamp)
Is it?
Thank you!
02-10-2021, 16:52
Hello,
finally I have found it!!
Actually it is a GESCO SECURVOX 833 but it is exactly the same of ALARMCOM (SIEMENS) SA 6.
If it can help someone, here below is the link to the instruction manual in pdf (sorry, it's in italian english but still helpful for anyone who needs to know exactly its pinout and how to connect to the head unit).
Thank you very much.
https://www.gesco.it/easyUp/file/manuali...CURVOX.pdf
