Jablotron JA-89 doorbell
27-10-2017, 16:31
Is it possible to get a text message when somebody push the doorbell? right now it works as a doorbell with a JA80L.
thanks! |
28-10-2017, 14:57
RE: Jablotron JA-89 doorbell
No its not.
This is because the doorbell is connected directly to the 80L. So the central unit does not recognizes this connection. Regards Christian Murphys Law: Man hat niemals Zeit, es richtig zu machen, aber immer Zeit, es noch einmal zu machen. |
28-10-2017, 15:19
Ah, okay... There is no way to programme it to the cetral unit? as a output or somthing?
29-10-2017, 01:20
Hi
You could use the 89 and program it as a PG Output (X) . This Will not start an alarm. Now you could send a SMS when the PG is activated. Web Tim Ich habe nicht auf jede Frage die passende Antwort, aber zu jeder Antwort die passende Frage. Auch wenn es Wenige ärgert, im Zweifelsfall geht mir Information vor Rechtschreibung. |
