Help with Jablotron OASIS
15-10-2017, 16:19
RE: Help with Jablotron OASIS
Hi Molino,
there exists no documentation for Olink.
On this site you will be find some manuals in english. Danish are not provided as i know.
https://www.jablotron.com/en/about-jablo...orm-submit
Changing the logo on the control-panel is a little bit tricky and in dependence which modell you have JA80F/JA81F.
There exists some threads with a how to but its in german only.
Have a look here.
http://www.alarmforum.de/Thread-Logo-%C3...light=logo
http://www.alarmforum.de/Thread-Logo-im-...light=logo
The picture format must be BMP-Format, 125 x 55 Pixel S/W as i can read.
As far as i know for the JA81F you must connect the CP (control pannel) via an additional bus-cable from the central-unit to the CP.
PC -> Central-unit -> control pannel
Normaly this add. cable is delivered with the cp.
Note that if you open the CP you trigger sabotage alarm.
This will happens with all sensors that you have registered with default configuration.
In this case the system must be in service mode until you close the cover.
By the way all maintenance works must be done in service mode.
For example changing batteries, moving sensors etc..
To change the display name is easy. This you can do in the menu "Texts".
Scroll down at the END and look at ID 720 this is the displayname.
Regards chris
Murphys Law:
Help with Jablotron OASIS - MolinoDK - 13-10-2017, 20:22
RE: Help with Jablotron OASIS - smith007 - 15-10-2017 16:19
  Jablotron Oasis Bedienfeld Text haribo 10 14.819 27-02-2014 00:04
Letzter Beitrag: ferris99
