  • 61 Bewertungen - 2.67 im Durchschnitt
Alarmanlage mit Internet-Anbindung
19-01-2010, 17:21
RE: Alarmanlage mit Internet-Anbindung
Hallo Herr Schnurer
Die Jablotron OASIS-80 (Indexa 8000) kann man mit dem LAN-Interface Jablotron OASiS LAN/PSTN-Modul JA-80V
auch per Internet Abfragen und Steuern:
http://www.jablotron.cz/upload/download/...a51202.pdf
ZITAT:
7.5. Remote access by Internet
The system can be accessed remotely via http://www.GSMLink.cz which
allows complete programming by installers and also operating the
system by end users. To access the system remotely it is necessary
to:
• Have the communicator connected to an Ethernet network which
allows access to http://www.GSMLink.cz
• Register the communicator via the GSMLink web page by:
o displaying http://www.GSMLink.cz and selecting New registration
o setting your login details (name and password)
o entering the communicator registration code (see the
communicator label)
o entering your system access code (user or service – this gives
you access to the user menu or the installer menu accordingly)
o after entering the above parameters it should be possible to
establish a connection with the system.
If your communicator is using a dynamic IP address when
communicating with the GSMLink server, then it could be that you
will have to wait for a connection (if your IP address has been
changed). GSMLink will indicate how long it will take to get
connection with the system. To shorten the waiting time it is
possible to initialise the communication remotely by dialling from a
telephone which has been programmed for this function (see
5.10.1).
• for further access sessions you only need to enter your login details
(these can be memorized by your web browser)
• several people can register for internet access to the system (both
installers and users)
• A service technician needs only one set of login details to access
various installations. After the first system has been registered, the
installer can add (or remove) other installations to(or from) his/her
GSMLink account.
• there is a demo version of remote access on http://www.GSMLink.cz
• using http://www.GSMLink.cz is free of charge
RE: Alarmanlage mit Internet-Anbindung - hawesch.de - 18-01-2010, 21:23
RE: Alarmanlage mit Internet-Anbindung - Toxx - 19-01-2010 17:21
  MB Secure Pro KNX Anbindung über Loxone? shaolinmaster 1 1.167 22-01-2025 17:11
Letzter Beitrag: walimex
  DS 6750 kein Internet/Gateway unibeta 13 6.978 08-08-2022 06:18
  Anbindung von Drittsystem zum Auswerten Moldi 0 2.171 16-10-2016 10:03
Letzter Beitrag: Moldi
  Problem mit PC-Anbindung (Winfem) tramrider 2 9.290 24-08-2012 15:51
Letzter Beitrag: Alarmstrippe
