Sirene Alarmcom/Siemens SA6
02-10-2021, 13:29
RE: Sirene Alarmcom/Siemens SA6
(02-10-2021 13:03)KMsicherheitstechnik schrieb:  http://www.mr-sicherheitstechnik.ch/kund...ge/SA6.pdf
Thank you so much!
I too found this one, but the pin out is different from the one I have.
I mean ... the pin out on my siren has 8 pins named:
> " X X X " the first three;
> " - Z + " the second three (- should be negative; + positive; Z probably is alarm signal coming from the head unit ...)
> " L L " the last two (L should stand for "Light" as I see they are directly connected to the flashing bulb lamp)
Is it?
Thank you!
Sirene Alarmcom/Siemens SA6 - Ross57 - 02-10-2021, 08:32
RE: Sirene Alarmcom/Siemens SA6 - Ross57 - 02-10-2021 13:29
