Response time for Abus 2WAY motion sensors - Druckversion +- Alarmanlagen-Forum - Alarmforum - Fachforum für Sicherheitstechnik (https://www.alarmforum.de) +-- Forum: Einbruchmeldesysteme nach Hersteller (/forumdisplay.php?fid=97) +--- Forum: ABUS (/forumdisplay.php?fid=167) +---- Forum: ABUS Secvest 2WAY (/forumdisplay.php?fid=134) +---- Thema: Response time for Abus 2WAY motion sensors (/showthread.php?tid=3016) |
Response time for Abus 2WAY motion sensors - olle - 28-11-2013 21:28 Hi all, I've installed the Secvest 2WAY in my house incl. motion sensors (PET) and magnetic contacts for windows. I've tested the buglar alarm when entering the house after a day at work, and also done "walk tests". The magnetic contacts react almost instantly. The motion sensors are very hard to trigger. Both in walk tast, and in real-life. I can often walk right by one without it triggering. The motion sensors are installed according to the instructions at approx 2,3m height. Any advice? RE: Response time for Abus 2WAY motion sensors - techniker28 - 28-11-2013 21:51 Manual page14: "Note: When delivered, the sensor cover may be set in the lowered position. Check this as a possible cause if the sensor does not detect any movement. Attaching" RE: Response time for Abus 2WAY motion sensors - olle - 28-11-2013 21:56 (28-11-2013 21:51)techniker28 schrieb: Manual page14: Yes, I've read that as well. I paid special attention to that line. I've compared the photo to the sensor's inside, but I see no match. I simply cannot see any possible way the cover can be in the lowered position. The thing/plastic that can flip according to the picture is not in my sensors. empty. RE: Response time for Abus 2WAY motion sensors - MGMGMG - 29-11-2013 08:13 I'm writing from my smartphone, so only a short note here ... Don't use PET motion sensors, this is pouring money down a rathole! They cause you exactly the mentioned problems! Is your PET a cat, just forget motion sensors. All they do is set off the lower area of the controlled area. If there is a fly above, cats will jump! The second thing is that a unwished person is able to get or creep through the sensor controlled area very easily. M. RE: Response time for Abus 2WAY motion sensors - olle - 29-11-2013 12:14 (29-11-2013 08:13)Mega X Sicherheitstechnik schrieb: I'm writing from my smartphone, so only a short note here ... Don't use PET motion sensors, this is pouring money down a rathole! They cause you exactly the mentioned problems! Is your PET a cat, just forget motion sensors. All they do is set off the lower area of the controlled area. If there is a fly above, cats will jump! The second thing is that a unwished person is able to get or creep through the sensor controlled area very easily. M. What? That can't be correct? I mean - then the alarm system is untrustable?? RE: Response time for Abus 2WAY motion sensors - MGMGMG - 02-12-2013 07:07 No. There's a lack of knowledge at you side. A professional would never use movement detectors in areas where pets move. In this case you got to make sure that your first "firewall" - the detectors at the windowfront do the job. I secure those houses with a sensor that detects the breach of glas, too. The detectors from ABUS provide the possibility, to attach those sensors. Then them have to be put on the Window -rim. Not at the side, guess why ![]() Regards, M. |
